Seat Belt Tension Retractor Levers What In The World?
4oldsmobiles64
35
74
Hello out there,
Not sure which thread BUT
Have an 1980 442
I bought 2 Seat Belt retractors to which the ad said 1978-1988 Cutlass - Regal etc. etc.
However these seem WAYYYYY too long.
When I try and install then they have quite a lot bend in the middle of them.
Will they still work?
Are they too long and are wrong length?
Anyone's suggestions would be great.
Thanks, Cory
69hurstolds
8,195
17,596
No idea if you got the right ones or not. They should be installed straight without bending. I’m thinking something is amiss here. You may have them caught up on something. Unfortunately I’m not at the house right now to check my parts books but IIRC the 2 door 78-88 are all the same.
4oldsmobiles64
35
74
I thought so too but when I install it - it goes through the eyelet hole - hit the back wheel well hump and the spiral copper looking rod is so long that there is around 1 inch more that sticks out to where the lever screws down in the door jam.
69hurstolds
8,195
17,596
78-88 uses p/n 20304170 pass side, and 20304171 driver side.
Do you still have your old ones to compare?
69hurstolds
8,195
17,596
After looking at a picture of how they mount, there is a bit of "S" bend to the springy rod when installed. But it shouldn't be sticking out by an inch or so. It has to sit in the release lever on the seat belt retractor, otherwise you won't have the belt retract when you open the door. Could it be one from a different body style? They are different part numbers, but as to what's different, I don't know.
Here's a driver side pic of how it should look.
4oldsmobiles64
35
74
I'm afraid I don't. I see that this one has a bend. Mine will fit too but it has more of a bend than that. It might work but it'll be tight.
Scoot-71
102
157
Rio WI
I couldnt get those thing in without removing rear seats and trim, maybe my talent level is low.......
