Can anyone enlighten me about shoulder retraction belts as my car had them cut out?
As I’m looking for a pair have all the rest 1979 coupe !! Thanks guys
Â
There's not much to them. The mechanized side attached 3 places - 1) between the seat and rocker panel into the vertical part of the floor; 2) by your head between the opera glass and the window; 3) fed through the rear armrest below the opera windows and bolted into a sheetmetal box bolted to the inner quarter. Then the retractor (black plastic lever on the bottom of the b-pillar edge when you open the door, down below the qtr vent and door striker) feeds through the metal, to the box, and clips onto the seat belt mechanism.Can anyone enlighten me about shoulder retraction belts as my car had them cut out?
How do you know if one can convert to retractable belts and where in the world is the placement for the mechanism? And thanks for your crisp explanation! Appreciate itThere's not much to them. The mechanized side attached 3 places - 1) between the seat and rocker panel into the vertical part of the floor; 2) by your head between the opera glass and the window; 3) fed through the rear armrest below the opera windows and bolted into a sheetmetal box bolted to the inner quarter. Then the retractor (black plastic lever on the bottom of the b-pillar edge when you open the door, down below the qtr vent and door striker) feeds through the metal, to the box, and clips onto the seat belt mechanism.
Installation will be first behind rear armrest panel, fed through and up onto the top mount, then last down to the floor
it's already a retractable belt. the mechanism is inside the column. what is it it you are trying to do?How do you know if one can convert to retractable belts and where in the world is the placement for the mechanism? And thanks for your crisp explanation! Appreciate it
Dez
In the 79 there is not retracting it’s a simple attachment. Over the b pillar. The belts were cut. I wanted to update to a more modern belts that is that rolled up belt in a compartment “of sorts.it's already a retractable belt. the mechanism is inside the column. what is it it you are trying to do?
Youre wrong, see my earlier post. Take apart the panels next to the rear seat.In the 79 there is not retracting it’s a simple attachment. Over the b pillar. The belts were cut. I wanted to update to a more modern belts that is that rolled up belt in a compartment “of sorts.
Sure will and I will get back. Happy Memorial Day! DezYoure wrong, see my earlier post. Take apart the panels next to the rear seat.
