I really miss an Olds powered truck, they made owning a truck fun. I almost pulled the trigger on a 94 GMC 1500 4x4 a year ago. It had the upgraded 14 bolt front axle. The price was fair, the 4L60E is always an issue with me, it made me think twice and skip it. It is a ticking time bomb, big time in a truck, actually used as a truck. I actually found a 95 GMC 1500 4x4. It is a drive, a trailer is needed due to the blown sbc 350 but being a 1500 strength wise is questionable. I actually have a motor in mind. I have a 403 block sitting and a complete stroker rotating assembly. I will actually have every part except a cam and machine for 424 ci 403 based motor. Build for torque with the Performer and I was thinking of building it, putting the 170cc runner #6 heads once the new SBO Olds heads come out and those go on the 358. Mark is working to convince them for a couple less CC in the chamber and SB sized runners. If that happens they would go on the 424. It will end up around 9.6 to 1. It would be a torque first and if horsepower comes, good. It would probably 400 hp and 500 ft/lbs pretty easy with iron heads, considerably more with the new aluminum. I was thinking of watching out for second gen Trans Am. Finding one that isn't a fortune, is the problem. Not sure I want another car needing every panel. This powerplant would destroy the weak 8.25 aluminum front diff and the 4L60E in a 1500, boom! I will be really looking for a decent body, non rotten 2500 for the strong diffs and a 4L80E. The 36 inch wide rad, the double thick core aluminum plastic rad would cool even a bored .039" oversize 403. Get second gen 403 Trans Am motor mounts, Transdapt adapter, serpentine adapter plates, a 94/95 with a blown 5.7 or 454 TBI would be ideal, best ECM and starting place. I like those years styling wise more than the earlier years. I would crank the fuel pressure to the max, a new high flow in tank pump, use the 454 TBI I have, new TPS and fix the hard throttle movement. The 454 TBI spacer allows antifreeze flow through it, great for winter. I would get the fully programmable ECM to really unlock the motor. The factory ECM would really not like a 220+ duration cam and needs a minimum 10 degrees advanced to even run on an Olds motor. My Dakota has numbered days, the next big issue, I am not fixing it. I may wait till every used isn't solid gold. Yes it would have the graphics in the title on it. Now just to find what I am looking for.
