Serpentine belt question
565bbchevy
565bbchevy
5,818
4,790
Michigan
#1
So I am adding a serpentine belt to my set up to drive my AC compressor and it will only be running from the compressor to the pulley on the crankshaft so my belt length will be approx. 54" and I am wondering do I need an idler pulley for this length.
I do have an adjustment to where I can tighten the belt.
20180804_190632_resized-jpg.94325
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
24,186
9,377
Kitchener, Ontario
#2
It looks like you have a 7 ribbed A/C pulley so with 7 rib belt I don't think you'll need an idle pulley
565bbchevy
565bbchevy
5,818
4,790
Michigan
#3
The crank pulley is a 6 rib and the compressor is a 7 rib, I was told by Vintage Air that they use a 7 groove to give options for alignment of a 6 groove belt.
pontiacgp
pontiacgp
Mar 31, 2006
24,186
9,377
Kitchener, Ontario
#4
even with a 6 rib I don't think you are having a problem....with all this talk about ribs I'm getting hungry...:)
Similar threads
