Im still using the computer i have a 02 sensor installed i dont want to remove it . I think the problem might be i dont have it at tdc It cranks right up and runs ok but the power is just not there .
Ok, if the computer controlled carb is not hooked up it will not run right. If the carb is not hooked up and running with the rest if the system, you are essentially throwing the computer into "Limpy" which is the "Limp Home Mode" of the software.
The Computer is looking for all its needed inputs to have the engine run correctly based on the EPA driven OEM method to keep the exhaust at the current 1984 standard of outputs, which is NoX, SoX, CO2, CO and Un-burned Hydro-Carbon.
When running a stand alone Carburator, you need to have stand alone timing.
Otherwise it will never run correctly. Low power, poor acceleration, run-on, and potential detonation and or overheating. The engine will run "labored", timing will not be correct, timing curve will be wrong, and engine damage is possible.
If you are running with the computer controlled carburetor hooked up, then the rest of the system including the carburetor, needs to be at OEM standard.
You have to remember in simple terms: Air, Fuel, Compression and Fire.... All has to be in proper balance.
The engine is nothing more than a "heat producing air pump". Volumetric efficiency is key and that was how it was designed with notable exceptions of EPA limits placed upon it.
On the distributor, hand crank (1/2 inch ratchet handle and socket) the harmonic balancer to an area where you can access the timing slot. Clean the slot cut into the balancer and then use white, or red paint pen and paint that slot. Let it dry..., then rotate by hand until the paint marked slot is at zero on the timing tab. Pull the cap and see where the rotor is pointing.
The copper tab on the rotor has to line up to just at the drivers side edge of the copper tab in the cap.
The rotor is carrying about 50K volts, so if the tab is lined up dead center with the tab on inside of cap, you are already too far advanced. If you pull the cap and the rotor is pointing to the firewall, put your pickup for the timing light on number 6, as number 1 is currently on exhaust stroke.
Remember 1 8 4 3 6 5 7 2... You have 2 rotations of crank to one of the cam.
