Hope all is well, G Body peeps!! I'll get straight into it.
1981 Chevy MC, stock rebuild 350ci, basic rebuild TH350 with shift kit, 3.42 posi. Everything else is pretty much stock. The posi was recently added after my original rear end crapped out. The new deeper 3.42 gears has obviously raised the RPM’s at higher speeds. No surprise there (I hope to get a 4 speed auto soon). What I wasn’t expecting was that my 1-2 and 2-3 shifts are coming in sooner, 13 and 20 mph respectively if I’m reading speedo correctly. I adjusted the modulator screw to its most inward setting, raising the shift points maybe 2 mph each. Still seems too early from what I remember the original shift points being. This was not noticeable before with my stock rear end.
I’ve done some research for over a week and learned that some shift kits add a spring (not included in stock transmissions) to the modulator valve which both firms and “lowers” shift points. Is this accurate? If so, should removing this spring raise shifts points a few more mph?
I know removing the modulator, with trans in car, will cause a small amount of oil to spill out. Will also removing the valve cause additional amounts of oil to spill or not really?
Any knowledge you can share will be much appreciated. Thanks in advance!
