shifter cable
Trader history for wonderboy24 (0)
wonderboy24
wonderboy24
1,227
Davenport, Iowa
i got 86 cutlass . looking for a floor shift cable. the one i have is to short.i have bought several that was told would work that they were 31 inch there were the same as the one i have .but same problem. i am in need of a 31 inch cable. i have a 29.66 length and it is to short. i know they make a 31 inch .rockauto sells them but they are out. i need it 31 full length eye to eye . thanks in advance
69hurstolds
69hurstolds
2,087
What transmission? 200-4R? Is it a stock replacement? Lightning Rods? Regular shifter?
4
403Olds
296
South Central Ohio
What transmission? I've got the shifter, cable and bracket off my 200C for sale. Let me know, I can go out and measure it.
69hurstolds
69hurstolds
2,087
When you say factory floor shift, you're talking 3 speed? Cuz a 4-speed one ain't gonna work.
Anyway, if you have a factory 3 speed shifter and a TH350, they never changed the base location of the regular shifter in the A/G bodies, so you should be able to use a genuine GM 22500579 shifter cable. This is the M38 (TH350) w/D55 (console) for 80 and 81 A-bodies. It'll fit 82-88 3 speed transmissions too, like the TH200. (NOT the 200-4R though)
One on ebay now for about 37 bucks shipped.
If that doesn't fit, you've got something wrong with either the shifter or transmission lever.
Length eye to eye isn't a huge issue as it is the total travel length of the cable movement from park to low that you need to worry about. Obviously it needs to fit the brackets correctly as well.
H
hoffa65
156
Atlanta GA
If they all are to short you most likely have a 4 speed shifter, the bracket that mounts the cable to the shifter is longer on the 4speed shifter. I have a 3 speed I will trade you for your 4 speed.
wonderboy24
wonderboy24
1,227
Davenport, Iowa
this is the factory shifter i run.
wonderboy24
wonderboy24
1,227
Davenport, Iowa
how long is your cable. the one i have is new. i bought it last year.i wouldnt have a problem trading you. let me know
H
hoffa65
156
Atlanta GA
measure from the cable bracket to the cable pin with the shifter in park, I will measure both the three speed and four speed shifter when I get home later tonight and we can determine what shifter it is, looks like a 4 speed from the pic
Thread starter Similar threads Forum Replies Date
H Wanted 1
