Show pics of homemade or junkyard front air dam
usetaboost
May 1, 2009
56
6
sioux city, iowa
Trying to find some ideas for a cheap front air dam to bolt up to the bumper. Yeah I could just do the GN thing, which I do have the single and two piece dams but I'd like to keep that stuff for the we4. Since this is a budget car I'd like to keep it cheap.
565bbchevy
9,614
12,683
Michigan
I made some ground effects for my 94' Lincoln out of pvc speed track and pvc tubing, I can't find any pictures but they can be seen in the video.
  • Useful
403Olds
533
424
South Central Ohio
I've been thinking of trying one of the air dam's off an 80's S10. I think it might be a little narrow, but anyone got a spare one sitting around to try out?
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,176
9,778
Gainesville, Fl
Check out one from a '90's Chevy Suburban. It might look similar to the S-10 piece, but wider. Also, I believe some Chevy pickups might have had them.
Comb your local boneyard, I'm sure you can come up with some creativity.
You didn't mention what type of car this was going on, I'm assuming a Regal. The fact that you mentioned a GN air dam.
I always thought one off a Colorado would look good. Kind of has a splitter look to it.
565bbchevy
9,614
12,683
Michigan
I think if you are going to try an adapt anything from a factory vehicle you will have to look for something with an extended front end where the spoiler will wrap around to the wheelwells most trucks will just be a front spoiler and will look unfinished if installed, the GN spoiler is a good example but because it is model specific it will not fit correctly on a Cutlass front bumper
