442 SI to CS Swap with Olds Rally Gauges Question
oldsofb
1,384
4,014
Maryland
All,
I'm doing a serpentine conversion on the 442 and I'm using the 91 S10 Blazer style CS Alternator. I have the Napa EC82 Conversion Harness that has the in line resistor. Will this work with the 442 Rally Gauges? Anyone done this swap recently?
Thanks in advance,
Hutch
88AZSS
435
1,098
Mesa, AZ
I know your question was particular to the 442 Rally Gauges but I can say that if theyre similar or the same as the Monte Carlo SS gauge setup as far as how they work, this swap will work just fine. I did the same alternator upgrade and my volt gauge works just fine. The harness you got with the resistor is the key to it working in the first place, this gives the alternator the correct trigger to continue charging.
oldsofb
1,384
4,014
Maryland
Thank you! I couldn't remember if the charge light bulb off to the right of the gauges served as the excite for the alt and the in-line resistor wasn't necessary.
Hutch
