Slow start
MadDrOlds
39
15
8
1985 442. New rebuilt carb. Starts every single time and idles fine. However…it is a slow grind grind grind start, which is more nerve wracking than it should be. Would electronic ignition fix this, or is it a different problem?
LeftLaneOnly
293
486
Sounds more like your not getting enough power to starter or starter needs rebuild
MadDrOlds
39
15
8
Ok, but when it is warm the engine kicks off immediately. Like right now.
If it was the starter, wouldn’t that be a problem every time the key was turned, and not a cold start?
MadDrOlds
39
15
8
In retrospect I should have been more clear on this point: if you leave it for four hours it is grind grind grind every time. If it has been running and you shut it off for 5 minutes and hit the key it fires right off. Battery was checked and pronounced good
jcelk
Dec 10, 2014
86
53
what do you mean by grind grind grind .doe;s it turnover slow or fast? or take a long time to start?
MadDrOlds
39
15
8
I take your question to ask whether it slows down like a weak battery in winter. No. Seems strong electrical, but just won’t fire off
Rt Jam
579
558
Ontario Canada
To clarify for everyone trying to help you here. The starter is spinning the engine fast, hold or cold.
That would narrow it down to ignition or fuel.
MadDrOlds
39
15
8
I would say yes, the starter seems to be spinning as it should--none of the real slow whuh whuh whuh you experience with a car at -15. When I have some time maybe I'll see if I can post a video.
jcelk
Dec 10, 2014
86
53
sounds like fuel problem next time starting it when it;s cold give it a shot of eather in the carb before you crank it ..if it fires right up it;s a fuel problem
jcelk
Dec 10, 2014
86
53
cheak the choke it should be closed and look down the carb and see if it;s getting a squirt of fuel when you work the throttle for the first time do this when it;s not running
