Small grinding marks and questions
Tony1968
2,319
5,112
NW Indiana
I have some small marks from being to aggressive while removing original paint. Bare metal now has 2 coats of epoxy. I can see them only on certain angles. Maybe I can get a picture if needed. My question is will 2k primer surfacer cover these or should I use glaze?
Also next question has confused me for awhile. Body filler going over the epoxy then I'll spot prime with epoxy. Then 2k surfacer. But if I miss some dings or whatever, is it ok to use body filler over the 2k?
I've read yes and no so there's my confusion 🙃
melloelky
4,155
9,548
mass
you can putty over sanded 2k..will 2k fill those grind marks?with a decent amount of coats probally but why rely on primer to do the filler work when skimming those marks takes little time.is your 2k direct to metal?
Tony1968
2,319
5,112
NW Indiana
2k surfacer is not DTM. Epoxy i used obviously is. I will skim them with glaze. Thank you sir. 😃
melloelky
4,155
9,548
mass
Don't get me wrong the primers up to the task but if you don't have to. I can see if you miss something towards the end then sure another coat or two/blocking will be the ticket
64nailhead
Goat Herder
Dec 1, 2014
5,695
12,175
Upstate NY
The 2K is crazy sh*t. A couple of coats will really solve problems. And it is easily wet sanded to perfection.
Tony1968
2,319
5,112
NW Indiana
Missing something is probably going to happen. 😆
I have a bejillion lumens of new led lighting but I have to bring a hand held to get closer view
Rktpwrd
Builder of Cool Shjt
4,166
23,915
Calgary, Alberta, Canada
Any particular reason you plan on only spot priming with epoxy? For the work involved to mask and shoot, and the small amount of epoxy product used, I wouldn’t bother with spot priming.
Do your filler work, lay down 2 coats of epoxy (over everything), then apply 3 coats of high build wet-on-wet.
Just my opinion.
Reactions: 5 users
melloelky
4,155
9,548
mass
Just my opinion.
i agree,i think he's epoxy'ing the break throughs to the steel from sanding the spotted in/filled in grind marks then the fill prime.i think.
Tony1968
2,319
5,112
NW Indiana
My problem is impatience. I just did the roof. I don't know if I can get it both quarters and trunk areas done by 4 day window. I'll do the rest of the filler then as stated. Then lay final epoxy and 3 coats of high build.
