Smog Manifold Tube
sldwys
126
66
I have an exhaust leak on the passenger side. It seems to be coming from the straight pipe section (the vertical piece) coming from these smog manifold tubes, it’s also missing whatever sits on top of it. Looks like it broke off or corroded off.
What piece is missing and how hard to replace? Is it worth it? I want to drive around without massive exhaust leak.
ssn696
Living in the Past
5,543
6,662
Permanent Temporary
There's a check valve. This ensures exhaust does not back up to the air (smog) pump.
sldwys
126
66
So just I’d check valve is broken off, this could cause exhaust leak? Just want to make sure before I go down this rabbit hole.
sldwys
126
66
Bump. Is this worth replacing and how hard to even get the bolts out? Is there a way to cap where the check valve broke off?
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,214
Yes, it would create an exhaust leak. You need to decide what you want.
Do you have an emissions program that you need to adhere to? Yes? Replace it. No? Weld it shut.
sldwys
126
66
I plan on doing an engine swap in the next year or two. So I want to enjoy the car until then. Really just want the exhaust leak fixed. I figured it will be hard to try and replace, especially unbolt 35 year old bolts that are in the exhaust manifold.
I don’t have a welder.
