smog pump question
ERIC87442
615
16
Monroe, Wisconsin
my car has been a part for about a year now, i was looking through stuff on thinking how it all went back together, i grabbed the smog pump and tried to turn it by hand, i could not turn it by hand at all, is this normal, maybe im not strong enough? :lol: or is it locked up and i gotta fork over some more money into it again?
azmalibuwagon
277
2
Phoenix
It's probably locked up They get moisture in them, and then if you let them set, they'll lock up. You can try to free it up, but most likely you'll need to get another. IIRC, they don't cost much.
ERIC87442
615
16
Monroe, Wisconsin
i looked at prices they are not that bad, just dont want to spend anymore money :lol: whats a suggestion on trying to free it up?
DoubleV
2,156
406
83
Medina Ohio
Just leave it off. It's not needed unless you have a visual inspection.
DoubleV
2,156
406
83
Medina Ohio
ERIC87442 said:
Going for a stock build i dont want to botch things on it either.
How can you botch NOT putting something on? :wink: Engine is WAY easier to work on without the AIR junk and it looks alot better too...and this is coming from a 'stock' kind of a guy who doesn't indiscriminately 'rip off all the emmissions junk' like many others do.
Plus i heard it can run funky without it too
No, this is not true I assure you. Not true in the least. If anything it'll run better....less stuff to go wrong.
Do what you feel you must, but don't do it for the wrong reasons. Removing the AIR junk on my otherwise stock 85 442 was the best thing I ever did.
megaladon6
4,006
15
Danbury, CT
unless it's a numbers matching car/engine, just lose the pump--they're worthless. all the AIR pump does is push fresh air through the exhaust to dilute the emissions measurement. lose the pump and plug the exhaust ports.
