white smoke is coming from the 3rd spark plug from front to back on the driver side directly from the hole does anyone have an idea what this could mean? I have a 307 y cutlass 83.
I put brand new spark plugs in the mechanic had said that one of the old spark plugs was wet when he pulled it out. It's not a thick cloud but it's visible it can be coming out of the header area right under that spark plug. The motor shakes also I think it's miss firing but it runs Smooth I'm confused rnSmoke should not be able to come out of the spark plug hole if the head and spark plug are good. Are you sure it is coming from the spark plug hole?
