so many different valves...
RustBucket
219
60
Houston, TX
trying to find the right size exhaust valve for my head with cast # 14101081
summit has two different ones. same valve diameter, but different stem diameter.
any of you guys know which is the one I need? thanks fellas.
MrSony
6,828
6,736
Des Moines, Iowa
One is stainless one is normal steel. Odds are the normal steel is the right one. Get a digital caliper and measure your stems.
  • Wow
spidereyes455
785
1,638
Northeastern PA
SB chevys only use an o ring at the top of the valve stem just under the keeper from the factory. Many times they get brittle and break apart. You can get umbrella seals and even positive seals aftermarket that fit over the valve guide and work better. As a personal preference I always use the o rings as well when I put positive or umbrellas on a sbc.
64nailhead
Goat Herder
Dec 1, 2014
5,708
12,215
Upstate NY
You have 'positive' seals on the your intakes and nothing on your exhausts. That is common due to the exhausts have pressure on the oil film between the stem and guide whereas the intake have vacuum trying to suck the oil on the stem into the intake port. It's a good idea to put new positive seals on to both (viton recommended), but it is not a requirement to have them on the exhausts.
Remember to lube the heck out of the stems and guides when you assemble these with OIL, not WD40 or anything else. Reason being that it take s along time for oil to get on the stem at initial, dry startup. You can destroy a set of guides by the time oil gets to them if they are not pre-lubed.
RustBucket
219
60
Houston, TX
Thank you sir, these are the comments that i learn from. I will definitely do that.
