So what did I do wrong
Gremlinsteve
345
426
i purchased a so called Monte Carlo ss
Steering gearbox from rock auto
I tried to install it today
I have also installed a new pitman arm. Something I read I would need. I'll have to get the part number to tell u guys what it's for
My problem is I can't turn the wheel. With the car on the ground it won't turn left or right
I have serviced the pump.
The car in the air...wheels turn with ease
I also obviously set the pitman arm up incorrectly as I can't turn left but can right. So I must not have the pitman arm centered correctly
So I am fighting two issues. One I think I can fix
The other I don't know
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Could you have switched the hoses from their right locations? Pressure hose is inboard (towards motor) and return is outboard.
Gremlinsteve
345
426
I'll check that
I looked at that specific routing. I am pretty sure it's correct but I'll check it tomorrow
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Do you have all the air out? With the car wheels off the ground and the motor running, try cycling the wheel back and forth a few times to 'burp' it. Check fluid level once you are done. Don't add too much fluid or it may foam on you.
64nailhead
Goat Herder
Dec 1, 2014
5,708
12,215
Upstate NY
If it turns in the air and not on the ground when running, then you have air as ssn696 mentioned. His recommendation is what you need to do to get the air out (as long as the lines aren't reversed.)
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Go to the gym. ;)
Gremlinsteve
345
426
Already did that
Gremlinsteve
345
426
Well
Spent today working on my el camino
I started the day by rechecking the hoses. They where installed correctly
I then moved to the gearbox. Tried purging the air from it by cycling the steering while the car was in the air
No worky. I simply can't get the air out of it.
I removed and reinstalled the original steering gear box at that point. Purged the air serviced reservoir and it was good to go
I must have bought a bad gear box.
Test drive it tonight and runs good.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Went through the same issue with 3 or 4 boxes.
The dope fiends they have rebuilding them have no idea what they are doing.
