i have a 2.5 Horsepower, 21 Gallon, 125 PSI compressor from Harbor Freight so it's getting plenty of air. As far as the water in the blasting gun..i did have a minor issue where i'd have to clear the tip...how does water get in the line and what kind of dryer/air control unit would i need? with this unit you just have to make sure there's always plenty of media in there b/c it's sucking/blasting like crazy. i'm happy with it..
My main question is that the baking soda that gets inside the frame....how or what should i do about that? should i degrease and pressure wash again after i finish blasting?? should i just blow compressed air though the holes to push it out? i was looking into the Eastwood Internal Rust protection spray and it looks cool to try on the front part of the frame that i've blasted....Any ideas..
Pics of the blasting results are here
viewtopic.php?f=13&t=36672
This is the Eastwood Internal Rust Protection
[/quote]
Well first things first I'm not an expert but I have learned alot from my father who uses high dollar compressors for a living in various capacities from wrenching to painting.
With that said any media is going to get in the frame when blasting. Just the nature of the work you are doing. I find that with baking soda you can usually just hose it off with high pressure air nozzle. I know some who also hose it with water and let it air dry. I don't like that idea but haven't done it to form much of an opinion on it. Water gets in the line from the air compressor. The compressor generates the water from it's operation of providing said air in your tank for your tools.
So the air control units (regulate air pressure to the tools) have water collectors on them too. This is all i'm currently using to stop water from getting into the hose to my tools. Painters use more more sophisticated air dryers than most to keep the water from entering their guns and being deposited in the paint (not a good thing right?) I use a Sharpe 606B air control unit. Traps water and you can drain it without shutting everything down. Examples would be
http://www.eastwood.com/dvb-qc3-air-fil ... dryer.html.
