motor mounts option/ install
bracketchev1221
1,405
1,639
Poly is good to a decent amount of power. 500 is a good reference point. If you need to do solids, solid on the driver side has been done for years. Finally, stay away from solid trans mount regardless of what motor mounts are used. Due to vibrations and alignment something needs to flex. I ran solid mounts and a rubber trans mount to 700 hp and solids and a poly mount to 820 hp.
DRIVEN
8,074
14,533
*CENSORED*
I was always told by my old gearhead mentors that solid only on driver's side for street cars. Vibration isn't the only reason. If the car is in an accident, you want the rubber to break away. Sucks if you bend a frame and sheetmetal. Sucks way worse when it shears your mount bosses on the block and brakes your tail housing too.
Just something to consider.
565bbchevy
9,611
12,668
Michigan
I think if you are hit hard enough to move your engine regardless of what mounts it has your car is probably totaled
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
our car hit the inside wall with some help, motor and frame moved enough for the upper control arm to put a dent in the header but the engine with solid mounts survived, was back on the track the next Friday with a new clip but with same body. With sold mounts you don't loose any inertia with the engine trying to rotate
DRIVEN
8,074
14,533
*CENSORED*
Yeah, that's kinda what I was getting at. Your car is probably done but at least you still might be able to save the engine and transmission for another car. Potato / pertater 🙃.
8,818
7,763
Melville,Saskatchewan
There is no polyurethane mounts for the Olds V8. The one solid from DMR and the Supercars Unlimited mount with a piece of chain on the rubber mount. Or jus try two of the Supercars ruhber mounts. I have yet to have a factory mount fail, you must have some serious torque to destroy them.
  • Winner
Bri guy
845
225
Car has never been on a dyno, but the previous owner estimates the car at 400hp and 475 tq. Not crazy numbers but these mounts didnt last long.....2 months on the car and probly driven 15 times before they broke
Bri guy
845
225
Decided to go with Oem mounts and will try to find a torque limiter or strap.....whats the best way to do this? Nicely jack up the motor just enough to replace the mounts?
Oct 14, 2008
8,818
7,763
Try the Supercars Unlimited mounts. They claim they are made by another company than the other mounts on market, usually under the Anchor name.
