Source for Quick Ratio Boxes? New/Used
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I have a 87 IROC box in mine with Jeep shaft. Makes a huge difference but turning radius does suffer
there is an adjustment you can use to shorten the turning radius, when you are making a tight or u-turn quickly press down the pedal under your right foot.....:)
Reactions: 5 users
oldsmobile joe
2,067
3,053
mpls
i prefer the iroc boxes my self. all my cars run them. why you ask?
first, they have one of the smallest pitman arm swings of that steering box generation. irocs have a 64 degrees of swing, regular f-body gears are 70 degrees.
by running the smaller swing, i have no or less issues with front tires rubbing the fender or fender liner at max turns.
second, by having all my cars running them, the steering is more consistent for me when i jump from one to another. yes i do loose some turning radius, but i compensate by swinging a little wider and turning a little earlier. you don't notice it once you get used to it.
i buy all mine used, mostly u-pull yard finds, and craigslist. all have worked fine and no leaks. maybe I'm just lucky.
here are a couple of links with more info.
https://www.chevelles.com/techref/shea_3.html
https://www.chevelles.com/techref/pdf/1983-96saginaw800fastratiogears.pdf
https://www.chevelles.com/techref/pdf/1992-98grandcherokeefastratiostrggear01ja2013.pdf
i measure the pitman arm degree swing before purchase by using the angle meter app on my phone. slick set up.
  • Useful
Ribbedroof
4,862
6,891
Wellston, OK
Here's where I got mine
Sorry, couldn't resist. Might have been the most usable part of the car
83beater
118
49
Got mine from napa
ssn696
Living in the Past
5,543
6,662
Permanent Temporary
Of course, there is the Jim Rockford one-point U-turn from reverse...
