Hey guys, months ago I posted about adjusting the rockers. Well i finally got around to finishing everything. (Head Gaskets). Now she wont start. Ive tryed everything...
It has spark. I changed the coil to a high performance one because I figured the spark might not be strong enough. I put on longtubes so I used shorty plugs. I took them out and put the stock ones back in to elimiate that variable.
She cranks and cranks and cranks. None of the almost catching thou.
Has fuel, even used ether. I can smell fuel on plugs. Its running an edlebrock 600 cfm carb.
I then figured it might be my rockers to tight and not getting compression. I back them off 1/4 turn. it has compression when I crank and stick my finger in the whole. Got a cylinder compression tester but it ended up being broke. Im going to get another one right now.
The engines out of an 87 SS. The cars a 78.
And ive checked the timing 5 times. TDC on #1. Ive triple checked the firing order.
The car also ran before i got it. This has never happened to be before so hopefully you guys can help!
Thanks, Matt
Thanks, Matt
