Spark plug wires
86pontiac2+2
132
96
While trying to determine if there is an optimal spark plug wire to use in my truck, I came across some info from the Magnecor website. Has anybody tested spark plug wires and wish to post their findings? How would such a test be implemented? 12v system with 45,000v pulsing coil to determine resistance? I'm not clear on how it would translate if most wires are tested under minimal voltage. Also, wouldn't 45,000v plus just flow through outer layer and not the center core? Just don't have a grasp on the whole concept of magnetic fields and electron flow, mind you.
From Magnecor. ..
http://www.magnecor.com/magnecor1/main.htm
Also, what are these all about? Why? How?
Porsche 944 spark plug wires...
