The rears come out from underneath the package tray. You remove them by popping the metal bail from out of it's slot, and then they should drop out pretty easily. As for the fronts, there was also a pretty rare Regal option that included 5.25 in mid woofers in the doors with tweeters in the dash in the stock 3.5 locations. It was called "Concert Sound II" and is very hard to come by. The door speakers had grilles that mounted to the lower door panlels. I have a whole setup because I am a bit of a junkyard dog and spent way too much of my youth scrounging around the U Pull Its pulling rare parts from unwanted late 70's and 80's cars that no one wanted at the time.
It is nice to have the door speakers because G bodies have terrible staging due to the tiny front speakers. They also respond good to a pair of subs because of the large trunk volume. If I were to build a system on a budget, I would probably get a decent deck with MP3 player connectivity and adjustable sub gain control on it. Then, I would get some mid priced 6x9's and try against hope to find the factory door speaker setup then run some decent separates up front. Add to that some inexpensive subs (at least 2 10's) like the Pioneer IMPP's and at least a 250-300 watt sub amp. Unless you are into music with a ton of Bass, you do not need very powerful subs to sound good. They mainly provide some power to the music. The subs in my truck are from the early 90's (10" IMPP's) with a donated Jensen 250 watt amp. The door speakers came from a wrecked Taurus and are by Cerwin Vega- I paid less than $10 for them! Just avoid Sony if at all possible as they do not seem to make a good head unit that lasts very long. Try the scratch and dent sales or try to get a display model at a major retailer then add the extended warranty. I have less than $300 in my whole system and it actually sounds good.
If you try to go speaker hunting in the junk yards, the best bet is to look at the imports. More of them are Youth owned and as such are more likely to have better speakers. The 3.5's I have for My Cutlass are JBL Coaxials I salvaged from a VW Jetta. Again, I paid around $10. You can sometimes find a factory component system in late model cars like Cadillacs and Buicks too.
