spectra fuel pump
donelle87ls
donelle87ls
9
#1
hello i have a 87 montecarlo with the tbi.
I ordered the spectra #sp172a1h sending unit the spectra unit has 2 pins as my stock unit has 3 pins that connects to the fuel wiring harness . is there a way that i can wire the spectra wires into the stock one.
donelle87ls
donelle87ls
9
#3
Does the Spectra have a ground tab? You should only need pump power and fuel level inside the tank; if you ground the assembly on top (outside of tank).
yes it has a ground tab would i need to splice the pink wire to get a read on the fuel level.
UNGN
UNGN
2,595
1,967
Southlake, TX
#4
The tank should have 3 wires: fuel pump +, Sending unit wire and common ground. What ever wire isn't 12 volts with the key on or makes the fuel gage move when grounded gets hooked to ground. (it should also show zero Ohms to ground on the multimeter)
Never trust wire colors in 30 year old cars. Test them.
Similar threads
