As for speedo to be at the correct/near correct road speed you have two options. Either match the in transmission drive & driven gears in the tail housing to a ratio that works with your 3.73's & the tire height (stock was 26" +/-.05") or get a gear reduction type box that goes on between the speedo cable & the speedo gear on the tail housing. As for replacing the speedo itself you might want to put an ad up in the wanted section for one but the '80-'85 graphics 120 units are pricey, go for a complete '87-'88 set ('86 is the same but with a 85 unit) & replace the original gauges (tach won't have a clock.) Another route is to get an overlay kit that will convert the speedo to the 120 you want but you'll need the reduction box or send out a good 85 unit to get recalibrated to 120.
