once you pop off the tailshaft of my new transmission the th350, you will see the speedo gear coming out of the bullet with the o ring on it going into the driverside of the transmission. then you will notice another plastic gear that the speedo gear goes into. isn't this called the running gear?
i need the correct plastic gears to make my speedometer work. can any of you point me to a product to buy these in order to work on my vehicle? i have a 1979 monte carlo with stock tires, stock rear end, and stock 305 sbc.
