what may be the cause of this ? I notice like a week or two when I hit 60 to 70 It start ed going back and forth ,but now today it doesn't work and stuck on 0
You have to pull the dash bezel out and get behind the speedometer itself. I would pull the speedometer out, unhook the cable from the speedo and see if you can twist the cable manually with your fingers. You shouldn't be able to rotate it. The cable is routed from the speedometer to the tailshaft housing on the transmission. Not a hard job at all. Could be a little time consuming if you haven't ever taken everything apart beforeIs the cable easy to change ?
Yea my tires are rubbing how can that cause it ?It could be caused by a tire rub
Yeah the needle was bouncingit can't, I posted that cause you left us hanging in your thread about the tire rub...
for a speedo it usually gives you some indications something is wrong before it stops working, like a squeak or the needle is bouncing
