SPIDER GEAR INSTALLATION
alrobjr
23
I removed the spider gears to replace them with new ones . I need advice on installing them in order , the rearend is a 7.5 10 bolt 2 series open carrier its a non-posi .
LS1GN
600
8
Central Florida
That's one of those things you have to fiddle with for a while - there is no particular order.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
First you install the side gears and then the pinion gears. The pinon gears need to be directly opposite of each other and then rotate the side gears til the pinion shaft can be installed.
