Good afternoon all has anybody used Spohn Performance control arms ?
Glad to hear you can report the good with the bad...They did take all the parts back and redo the finish... I am happy with the way they work.
I have Spohn "Tall Spindle" uppers to accommodate my taller ball joints. They're shorter than stock. You don't need them but it cuts way down on shims. They've been treating me well.
It sort of is the same in the sense that you’re adding height to the spindle and ball joints (as a whole) in order to get the upper a-arm pointed away from the ground. IIRC, Blazer spindles (which I used; not B-body spindles) are about the same height as G-body spindles. I used tall ball joints on them. But even on the G-body drop spindles I used previously, with even just the upper tall ball joints you still have to add more shims to get the camber back where it was.those particular arms you have are designed for running a larger rotor and spindle combo from a larger car like a caprice on our mid sized chassis. running taller BJ's on these cars is not the same thing as the swap you did.i just don't want the og poster to think they're in for a whole lot of work.
