I‘m in the process of refitting the passenger side power window regulator on my ’82 Cutlass. The regulator mounting is spring loaded and needs to be rotated about 270 degrees anti-clockwise to line up with four mounting holes on the door frame. The problem is, the mounting is spring loaded with so much tension it’s virtually impossible to force it much past 180 degrees (… and yes, it did nearly slice my fingers off when I removed it!)
My question is, how do I do I safely re-tension the spring loaded mounting and line it up with the mounting holes without losing a finger if it slips? Would the window motor have enough power to lift the window if I remove the spring?
(Just in case you were wondering why I loosened the regulator in the first place, it was to remove and check the power window motor – the motor is mounted on to the regulator with three bolts but GM only made one access hole to one of the bolts! I have since found out that I could have cut two access holes in the door frame to get at the hidden remaining two bolts – it turns out GM were helpful enough to punch two dimples in the door frame to show you where to cut… but that’s a little late now!)
