Squeel in dash
Lentzjj
n00b
Mar 28, 2018
I have a really annoying sqeeling that sounds like it coming from the dashboard. I only makes noise while moving and engine rpms don't seem to have a effect but speed does. So best thing I can figure is that its the speedometer cable or speedometer itself which does a steedy jumping move. Anyone ever have the cable make noise? I never heard of this happening before.
The car is a 85 v6 regal limited
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,174
9,776
Gainesville, Fl
First off, you may want to post a proper introduction telling us what you're working on, etc. before making your first post a question.
Secondly, your problem is a common one with G-body cars. The rear pad or rubber cushion supporting the rear of the hood needs a dab of white grease to eliminate the squeak.
Lentzjj
n00b
Mar 28, 2018
gotcha just seems like more of a squeal then a squeek
Longroof79
Oct 14, 2008
12,174
9,776
Gainesville, Fl
If you suspect the speedo, try disconnecting it temporarily at the trans. While you have it disconnected, for test purposes, hook up a cordless drill up to the cable and set it on counter clockwise and see what it does.
Wageslave
1,749
3,338
It sounds like your speedometer cable is in need of lubrication. Pull it off of the speedometer and pour a little bit of oil into the end of the cable while working the center of the cable in and out slightly. This should fix your squeak if the cable is not damaged. If it is, you may have to replace it.
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
Steady squeal is usually a belt under the hood. Speedo cables usually chirp, but the lube does dry out.
Remove gauge cluster, remove cable, put some grease in a sandwich bag, poke the cable through the corner, and feed it back in. Reinstall gauges.
  • Creative
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I put my money on the rubber hood support near the firewall. Put some grease on it and and the noise should be gone
airboatgreg
2,867
3,115
My guess is a speedo. Easy and cheap fix. Remove from under dash. You have to push release and be a bit nimble. Remove inner cable, clean with a solvent, light coat of lube and you should be good to go
Lentzjj
n00b
Mar 28, 2018
Rubber hood gasket has been lubbed up already going to have to get that cable lubbed just wasnt sure if other people had that issue thanks
