I have not had this out on the road (other than some drives around the block) in about 8 months. I was working on replacing all the brakes and lines. A few questions: 231 Buick engine.
1) idles and revs fine in park but when in gear it stalls if I hit the gas kinda hard, timing issue, accel pump, ?? It’s has a Rochester 2jet.
2) choke seems to work as it should but when I would drive somewhere and then go start it back up, it won’t start. Unless I open the butterfly a little. This is when warmed up.
Thanks for the responses. Everyone is always helpful.
