starter isse
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
There should be 3 wires 2 go on the large "MAIN" post and the small one on the terminal marked S
The terminal marked R should have no wires going to it in a G-Body
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
my starter has 3 post and i got 4 wires for some reason
you should have 2 read wires with the fusible links and they go on the terminal with the battery cable. The purple wire goes on the S terminal. When you had the proform starter did it ever work properly?
mike reese
22
it worked fine until the other day. that when it stopped turning over and i got a horrible grinding sound. once i get home i will post a pictures of the wires thatbi have
Andrew Sultan
12
So I have had a similar problem, but my engine will spin for a little an also is very slow, I changed a cam and I've gotten the starter tested and the guys say it's good but when I put it in it won't crank I have a red top optima battery and it's not bad my starter did work before but now it's not I don't get i but my starter only has one where the positive and negative go together, is that right?
