Hi all,
I've got my GP ready to fire up. I had it running this afternoon, but it won't stay running. Anyway I need some help with my starter wiring.
I have 2 red wires with the fusible links connected to terminal S and my battery lead connected to the larger post.
I also have a 10 gauge purple wire that my wiring diagram shows need to be connected to the other small terminal on the solenoid. Is this correct? When I connect the purple wire to either starter terminal, it won't turn the starter. In fact I have no power in the entire car. If I connect it straight to the battery, I can crank the engine, but still no power to the rest of the car. Fusible links are good, I checked them with a continuity tester. Trying to figure out what I have wrong, and how it's supposed to be.
Thanks,
Tom
Thanks,
Tom
