Just want some ideas what you guys do when starting up a new/old engine after a year... So I finally completed my tpi swap engine sat a year prior to swapping it in. I put a liter of oil down the heads on either side spun crank by hand 5 times or so and crank motor for 5 seconds with fuel pump relay removed... Oil is all fresh and level even filled out filter... I'm going to be firing it tomorrow at some point and suggestions or any recommendations you guys have?
