so far 3 bolts are just spinning , so since i cant see inside as it's spinning what are my options here.. what do i do? i need to get the body off this frame since some have broke. i feel like i'm kinda screwed
Coveted said:cutting 3 sides of the floor where the bolt is would be better than a hole saw, more work, but then you have a tab you can bend back down and weld back in. trying to weld the cut out from the hole saw might be a pain
Chopper said:Coveted said:cutting 3 sides of the floor where the bolt is would be better than a hole saw, more work, but then you have a tab you can bend back down and weld back in. trying to weld the cut out from the hole saw might be a pain
You are right. Leaving a flap piece of metal is a better choice for sure.
CWPottenger said:Chopper said:Coveted said:cutting 3 sides of the floor where the bolt is would be better than a hole saw, more work, but then you have a tab you can bend back down and weld back in. trying to weld the cut out from the hole saw might be a pain
I used a hole saw and then put body plugs in place so if for any reason had to pull body off again would be easy.
Chopper said:Actually I thought about using a body plug too but most people probably like it welded. How big a hole did you have to cut? The plugs for the door wiring are about 2 3/4" and that looks like plenty of room (probably more than needed). I have one broken cage already so I know when I go to pull it off frame, I will most likely have more.
