I need the two lines made for the steering box in the wagon. I had a shop make the two for the coupe and they did a perfect job. Only thing is the coupe was flare, this one is O ring. Both boxes were done by Lares. Both close ratio for a sport suspension.
My question is are the fittings using O rings metric or standard ? 16 and 18MM ? Ive got nothing to check them with and Lares is closed until Monday AM. Externally the boxes are the same. Just the flare/O ring fittings make the difference.
Im assuming the new pump on the crate motor is also metric. Anyone know for sure ?
