Steering column parts needed - is used the only option?
64nailhead
Goat Herder
Dec 1, 2014
5,697
12,185
Upstate NY
I’m looking for the Jesus clip for the lock plate, spring for top bearing tension and the collar the spring rides on (see photo).
Ive hunted for these online at parts stores, but no luck. Are these same in most columns of the 80’s era?
64nailhead
Goat Herder
Dec 1, 2014
5,697
12,185
Upstate NY
Thanks - I can see junkyard in the near future.
69hurstolds
8,185
17,568
There is a GM part number for it. It's GM # 5694191. Still available from GM. $10.14 list price. Ring, Lock Plate Retainer.
Of course, that'd be last resort. I'm sure if you take your lock plate compressor with you, you can find a bunch of them at the treasure yard.
Reactions: 6 users
69hurstolds
8,185
17,568
As far as the spring...tilt or non-tilt?
Tilt- 7815185 Still available from GM. $16.58 list price.
Non-tilt - 7819898 - no longer available from GM.
  • Informative
69hurstolds
8,185
17,568
Bearings and seats/retainers and junk? You'd have to buy bearing and spring kits. Generally not serviced separately.
7844650 tilt spring kit has the bearing races/seats.
The upper bearing not serviced separately, but would come in the rack kit. P/N 7844651.
Reactions: 6 users
64nailhead
Goat Herder
Dec 1, 2014
5,697
12,185
Upstate NY
This place seems to have a bunch of good info about steery columns, but buying junk from them can be PRICEY!!! But he sells a spring and retainer/seat as a little kit by itself. For almost $60!!!
gm, buick, cadillac, chevrolet, oldsmobile, & pontiac steering column housings and bearings brg02 Tilt Housing Bearing Retainer Kit | Steering Column Services
Thanks. Seeing the range of years tells me I should be able find one at the junkyard.
I won’t be spending that much unless it’s a last resort.
64nailhead
Goat Herder
Dec 1, 2014
5,697
12,185
Upstate NY
I’ve torn the column down to the pivot and the 4 bolts weren’t loose. Appears there is a nonfunctional snap ring or retainer lower in the column which is allowing the shaft about 3/4” in and out movement in the column.
Digging deeper.
  • Wow
Texas82GP
Just-a-worm
Apr 3, 2015
7,987
18,693
Spring, Texas
I found a great online reference on working on those columns. I have a hard copy at the office (only place with a printer that could print it). I'll post a link tomorrow. I'm going to send myself a reminder now....
