I’m putting my column back together after fixing and painting where the shifter used to be and installed a new turn signal switch and cam. Afer all thats in I installed the new Grant adapter kit and steering wheel. This is a 79 Elco with a tilt column. The entire upper part of the column from the tilt joint up is loose and wobbly. I know I tightened everything down real good. Has something in the tilt joint gone bad ? Again, one step forward, three steps back.
