Steering column repair questions
Bri guy
845
225
I had replaced my tumbler and tried to tighten up the wobble while it was somewhat apart. Couldnt get to the "3rd" bolt. But when taking the column pcs out, this "ring" thing popped off and wont stay in place. I think it wedges in between the bearing and that shaft that the steering wheel attaches to. So i bought a rebuild kit off amazon and will be getting it hopefully by friday. But what keeps that "ring" in place? And what should i use to pull that bearing out?
RabbitHoleSS
712
2,105
Indianapolis
He shows you how to fix the tilt column wobble and has to disassemble the entire thing to do so. Id bet the answer you seek is in that video. He does a great job explaining step by step.
Bri guy
845
225
I seen this video as well as others. But I will watch it again. Maybe i missed it
Bri guy
845
225
Perfect. I see it now. I didnt watch it far enough into the video cuz mine popped out right away and he didnt take it out til way deeper in the process
Bri guy
845
225
So it looks like he just throws it in and its good....but i did the same and it just falls out...anyone dont this before
smartin3
24
50
13
I did this job last year using the video below. To save you some time, it starts at 22:00.Good luck!
Made an edit to the time stamp. I originally thought you were referring to the ignition piece.
20,391
this thread reminded me to go pick up a steering column from a G body so I can work on that one to I can make a manual steering column with the manual non-tilt column I bought from clean8485 last year..... :popcorn:
Bri guy
845
225
I wish i could find a tilt whithout the shifter on it around my area....nothing here....
20,391
just keep looking and one will show up or you could always cut the mounts for the shifter and paint the column..
Bri guy
845
225
just keep looking and one will show up or you could always cut the mounts for the shifter and paint the shaft...
I thought about doing that. I forget that dang shifting collar can move and wont let me start the car if it does.
