Added a power steering cooler from a KIA SUV. I now have the engine, transmission and power steering air coolers installed.
Update: Return hose is installed, and the cooler has fluid going thru it since it gets warm. The cooler is in the path of air coming out of the lower part of the e-fans, so it is in a good place.Added a power steering cooler from a KIA SUV. I now have the engine, transmission and power steering air coolers installed.
it sits at the rear where air flow from the e-fans pushes air over it. In the hot TX summer my temp doesn't get over 200 with the coolers and AC Condenser in front of the radiator. The Sebring fans move a lot of air.Be careful of adding to many of them directly in front of the radiator-A/C units. Not just adding more heat that wasn’t there before but it can add air restriction. As long as there is air flow around the steering cooler it will help. Nicely mounted.
Sweet!!it sits at the rear where air flow from the e-fans pushes air over it. In the hot TX summer my temp doesn't get over 200 with the coolers and AC Condenser in front of the radiator. The Sebring fans move a lot of air.
did you get all 3 coolers from the same Kia suv? and you didn't have any problems with connectors, they're all the same size?Added a power steering cooler from a KIA SUV. I now have the engine, transmission and power steering air coolers installed.
the oil cooler AC Delco from a big Chevy SUV, the steering from a large KIA SUV and the transmission is the generic cooler sold online. I'm planning on switching that one for a GM trans cooler when I find the right size. It takes me time to find a vehicle that isn't destroyed in the front at the local pick n pull. The lines are 3/8 so no problem mating. GM has some nice trans coolers too but they were all beyond recognition. Some are just a long winding hardline that passes in front of the radiator. What I do is google oem coolers and find an image of what i think could work and then hunt for one at the yard and see if its good for what I had in mind. The KIA one was just a lucky find since i wasn't looking for anything from a KIA.did you get all 3 coolers from the same Kia suv? and you didn't have any problems with connectors, they're all the same size?
well, you can always drive over to Snyder's WAP in Holland but they pull all the engines/transmissions there so the front end is usually gone. and the WAP down the road from you had that big fire a couple months ago so....🤷♂️the oil cooler AC Delco from a big Chevy SUV, the steering from a large KIA SUV and the transmission is the generic cooler sold online. I'm planning on switching that one for a GM trans cooler when I find the right size. It takes me time to find a vehicle that isn't destroyed in the front at the local pick n pull. The lines are 3/8 so no problem mating. GM has some nice trans coolers too but they were all beyond recognition. Some are just a long winding hardline that passes in front of the radiator. What I do is google oem coolers and find an image of what i think could work and then hunt for one at the yard and see if its good for what I had in mind. The KIA one was just a lucky find since i wasn't looking for anything from a KIA.
