is it new or second hand? I only ask because in my experience they have to be heated to melt whatevers keeping it from collapsing.i couldn't get it freed up otherwise.Can anyone who has used the Jeep steering shaft to upgrade their ride tell how in the world I get the shaft length extended like it's advertised to do? I don't want to beat on it with a hammer. Any advice?
Thanks. Before I start beating on something I want to make sure that is what is supposed to done.Mine is pretty tight, I think I bolted one end up and rubber mallet tapped on the other end, it eventually went to proper length. I squirted some silicone spray in it, seems to help.
it's new.is it new or second hand? I only ask because in my experience they have to be heated to melt whatevers keeping it from collapsing.i couldn't get it freed up otherwise.
Thank you.If the length does not float. Throw it out.
When the frame is moving around, relative to the body. Your column bearings and the steering box bearings will not be happy.
