Stereo Sound in an '84 GN
hot air 84
10
11
My son is giving me a 15 inch sub-woofer that he had in a previous car of his. I know all Delco systems use ungrounded speakers and my owner's manual cautions against adding a CB for example, as it could damage the speakers. I am looking to see what i might have to add to drive the existing speakers and the sub.
There doesn't appear to be a model no. anywhere on the radio. The only number is AB09GNFM20E.
It is a basic AM/FM cassette stereo unit.
Any thoughts or suggestions as to how to add in the sub?
hot air 84
10
11
So it's not the stock stereo, so does the day 2 radio have RCA Jack's in the back or it's not that modern
No, it is stock - I'm second owner - bought 1988 - change radio out and saved original. Put original back a fews years back . Radio dates to 1984 when car was manufactured.
g0thiac
939
582
So if it's not an aftermarket one with the 2 red & white RCA jacks... and is the original Delco cassette player? Then use a line output converter, and it doesn't have to be this exact one either.
Basically, you cut all 4 rear speaker cables, and make Y cables out of them. So 2 negatives and 2 positives for the speakers, and 2 negatives and 2 positives for the converter.
You will also need a good amp. That will be powered by some cabling between 2 to 0 AWG that runs from the battery, through a 100A mega fuse, through the firewall, down by the passenger side floor, behind the rear seats, into your trunk.
MrSony
6,828
6,736
Des Moines, Iowa
Find an EQ tape deck. Quite literally 2-3x louder.
mclellan83
4,258
9,452
Pgh, PA
This could get fun
