Still Have One Wire With No ID
mikester
2,904
3,641
Small town NY
Guys, Im down to one wire on the Alpine stereo that Im putting in my wagon. Its the yellow wire for constant power/battery. I figured I would just run it to the fuse block. No big deal.
I still have this one wire under the dash. I have no idea what its for. I dont think anyone could ID it in my other threads.
Its a single brown wire.
I cant test it. Ive got no engine harness in and I wouldnt know where to begin trying to get power to the fuse block.
Can anyone ID this wire and plug ? Its in my 83 Malibu wagon.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
The blower switch uses a yellow wire for the slow speed so it would be switched...why not tap into the lighter wire, it's fused in the fuse box
mikester
2,904
3,641
Small town NY
I should have explained this better. The stereo has one wire that needs to be hooked up to constant power. Figured it would just be easier to run a line to the fuse block than to tap into the lighter hot wire. Especially since Im soldering and shrink tubing all the connections. I still dont know what this brown wire is for though.
84 W40
567
782
That wire I think controls the stock radio lights when you turn on the head lights i could be wrong. Check it with a test light and turn the head lights on.
mikester
2,904
3,641
Small town NY
LOL, did you read the whole post ? The motor and everything under the hood hasnt been installed. Ive got no engine harness and I dont know what I could use to power up the fuse block. In other words, cant use a test light.
From what Ive been told, this is one of the radio harnesses. Yellow was keyed power, black is ground and gray is illumination. Those wires have already been used.
1evilregal
3,056
4,357
Greensboro, NC
I'm remembering something on that brown wire, but not sure if I'm right. I think it goes to the heat/ac circuit somehow... then again, that may be why I have a draw on my battery....
1evilregal
3,056
4,357
Greensboro, NC
^ the grunt types faster than I do! :sleep:
