1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
WANTED Still ISO late 70s Buick 350 4 Barrel Throttle Bracket
Discussion in 'Wanted' started by MrSony, May 18, 2017.
  1. MrSony
    MrSony Comic Book Super Hero
    Nov 15, 2014
    3,203
    862
    Des Moines, Iowa
    Bracket on the intake to the right of the carb. Needed.
    Picture from JoesRegalProject
    #1 MrSony, May 18, 2017
  2. 307 Regal
    307 Regal Royal Smart Person
    Oct 21, 2009
    1,448
    238
    Northern Indiana
    Wish I could help but I'm using a Holley with a cheap universal bracket. Could you use a stock G-body 4-barrel bracket?
    Also, if the engine isn't in yet, I really recommend you check out the status of the oiling passages. Especially the one that's (I believe) a valley in the front (or so) cam journal. If that's clogged, you'll have noisy driver's-side front rockers. I have this issue.
    Lastly, might I ask what car that engine was pulled from? That power steering pump mount angle looks way better for cornering than the 3.8 V6 mount.
  3. MrSony
    Nov 15, 2014
    3,203
    862
    Des Moines, Iowa
    Tried every bracket under the sun. has to be that exact bracket. The brackets that hang off the back of the carb hit the intake. I don't really know what the engine was pulled from, as it's not mine, probably a 76 century or something. Pic is of JoesRegalProject's engine in his build thread. I used my V6 PS bracket, so it's offset to the drivers side a bit more, but there is a PS bracket on ebay IIRC. non smog pump mount so it looks really clean. Here it is: http://www.ebay.com/itm/1975-Buick-...ash=item1ec5429234:g:UvwAAOSw2gxYvtDL&vxp=mtr
    • Like Like x 1
    • Informative Informative x 1
  4. Texas82GP
    Texas82GP Comic Book Super Hero
    Silver
    Apr 3, 2015
    3,974
    2,888
    Spring, Texas
    Have you looked at the bracket for the square body trucks?
  5. MrSony
    Nov 15, 2014
    3,203
    862
    Des Moines, Iowa
    I don't believe they would work. On Buick qjets, the throttle arm is different than a Chevy, and the top nub is about an inch higher and the bottom about a half inch lower. Cable alignment would then be an issue. And the bracket's gotta have the two holes for the kickdown and throttle.
  6. pontiacgp
    pontiacgp Canadian Prime Minister
    Mar 31, 2006
    20,969
    2,645
    Kitchener, Ontario
  7. MrSony
    Nov 15, 2014
    3,203
    862
    Des Moines, Iowa
    He never responded. I've messaged him multiple times.
  8. pontiacgp
    Mar 31, 2006
    20,969
    2,645
    Kitchener, Ontario
    that is strange cause I have had no problem with him getting back to me and he responds quickly
  9. MrSony
    Nov 15, 2014
    3,203
    862
    Des Moines, Iowa
    Got two convos, on in Feb one in April, no replies on either. I do hope the one he has is the correct one.
  10. pontiacgp
    Mar 31, 2006
    20,969
    2,645
    Kitchener, Ontario
    report him to the BBB.....:D
Loading...
Similar Threads - Still ISO late Forum Date
ISO REAR WINDOW TRIM Wanted Jan 13, 2018
ISO Spoiler Wing Wanted Sep 14, 2017
ISO 1pc V8 fan shroud Wanted Jun 7, 2017
ISO 79-80 Monte Carlo tail light Center plastic. Please contact if you have this part Wanted May 23, 2017
WANTED ISO Olds Headers Wanted May 21, 2017
Share This Page
