For those of you who haven't seen my posts lately, I'm doing a 'quick and dirty' rebuild on my '76 Buick 350. I'm doing a flex hone on the cylinders, re-ring, new crank and Rod bearings, timing set, and gaskets and seals. I want to hop the motor up a little, and do it on the cheap. I've already found a used comp cam with it's original lifters to use.
The stock compression ratio of my engine is 8.5:1. However, the 1970 and earlier 4 BBL Buick 350s had different pistons and were 10.25:1 compression. Now, obviously I probably won't get to 10.25:1 because my heads are different, but I can probably get in the 9.5-9.75:1 range by using stock 1970-earlier 4 bbl pistons.
So I'm trying to find stock, standard bore pistons from a 1970-earlier Buick 350 4BBL. TA Performance sells forged ones, but they are in the $400 range. I see that RockAuto carries several sets of pistons, but they don't list the compression ratios. Can anyone who maybe knows a bit more than me help me out?
