Looking through old postings from various sources, there was a lot of conflicting intormation even years ago. Some posters even got in fights over what the correct fuel pressure specs are. Moreover, I believe that 9 psi is too high for a Qjet. On Ciff's forum, he states 7.5 psi is generally as high as you want to go with Qjets.
On another forum, a poster suggested to me to use a Carter M6101 as its supposed to be a correct replacement pump. However, there is again conflicting info regarding this pump. Summit and Jegs state the Carter M6101 produces 6.5 psi while Rockauto and Carter's own website state it produces 9 psi. Not sure who to believe.
Guess my other option is install a dead head fuel regulator between the pump and Qjet. Through it would be a mess to run a new pump to carb line. Not sure if I should give the Carter pump a try or just get a regulator.
