stock shifter handle operation
Cutty1
412
2
metro detroit
i have a stock shifter handle to put in my car because i dont have the original one in there now but can someone kinda tell me how this goes .. and inside the handle is there suppose to be a spring in there?i'm missing the spring if so.... and i'm just not sure how it operates you push the side button how would that push down to put it in gear?
LS1GN
600
8
Central Florida
If the spring is gone then I don't know how to fix that. In mine (Monte SS) there is a little plastic piece, which looks like a pearl necklace, it bends around the corner from the button down the shaft. It takes the lateral movement and transfers it into a vertical movement.
Probably a lot easier to find another- Ebay? Junkyard?
Cutty1
412
2
metro detroit
ahh really damn that sucks... yea the inside of mine is empty so i just wasnt sure what i'm missing
Evan11
1,259
10
38
Southern Indiana
Yep, there's a spring that goes on the inside. Most of them on eBay don't have it or the chrome pieces. Good luck finding one in a junkyard, seems the handle is always missing. Come to think of it, there was a handle for sale on here bout a month ago, do a quick search. Keep in mind the regal and cutlass use the same one.
Cutty1
412
2
metro detroit
ok i actually took it apart and there is everything in there just spring alittle wore out, but i'm mising this piece whats a j rod? and not sure where it goes can someone post pic?? is this for the automatic?
Oldsmobile J rod Shifter Spring
The J-rod shifter spring goes underneath the J rod & allows it to stay in the up position. When you push the button on your shifter the slider button pushes down on the J-rod to allow it to go thru the detent bracket notches. The spring pushes the J-rod back up to lock you into a desired gear postion.
If you do not have to push the button in on your shifter & the shifter does not lock into position this is most likely the culprit. They have a tendancy snap in half over the years or simply fly off the chrome shifter.
*free shipping USPS when ordered by itself.
