Strange sound and smell of gas
rogus
309
84
Yesterday was fairly warm here and I noticed a strange sound Coming from my 81 Elky followed by the smell of gasoline. Fairly sure this was caused by fuel coming under pressure in the tank as it heated up during the day. Any ideas on how to fix this?
ck80
Moderator
Moderator
5,742
9,114
How's the tank vent/charcoal canister/lines, etc?
I've seen people plug them with golf tees and hose clamps to eliminate a gas smell from a damaged system and screw up the venting in the process
rogus
309
84
Unfortunately it no longer has one. Someone did a real number on this car mechanically before I bought it.
Burd
248
230
Detroit
The One on my 78 went. All the pellets get sucked up in the carb. Nice. Just after I had it rebuilt. So I put one on fir a GN. It was the replacement part. Works great. No smell
I heard guys putting a riding lawnmower gas filter on the purge line so if it let’s go the filter traps all the pellets.
rogus
309
84
I need to find something. Dropped the tank yesterday and found what looked like a 3rd metal that used to run back to the tank.
Burd
248
230
Detroit
When my mechanic put the new canister on, f body’s, have rubber lines in 3 places on the metal fuel and return lines, we replaced them, about a qt if water came out of the return line, I replace the gas cap too then, wrong cap? Canister wasn’t hooked up rite? Not sure.
bracketchev1221
1,386
1,599
I agree, no reason to eliminate the charcoal setup. I know as a kid, it was emissions and not performance so it went. But now being older and grumpy, there is no reason a fast car can't have one. Years of racing taught me things that actually did make power and other stuff was just magazine stuff and stupid. And I won't deny I had to learn A LOT the hard way.
rogus
309
84
unfortunately none of those parts are still on my car
ck80
Moderator
Moderator
5,742
9,114
It's not that hard to add it back. You buy a canister filter, run the hose routing according to the pictures on an emissions label from your year/make/model, and get pieces of rubber line to plug it together.
So does the fuel line still connect to a three line sending unit, or, did they swap it to a two line sending unit and just leave the old line running down the body/frame rail?
Burd
248
230
Detroit
Swap meet. Look up your part #. It’s usually on the top of the canister.
nOS ones are getting pricy.
