Hello,
I have a 1984 Pontiac Bonneville. My fuel gauge is stuck at 1/4. The ground at the body was corroded. I decided to pull the tank and inspect. The top was rusted. the lines were leaking from the sending unit. Tested the sending unit and couldn't get an accurate reading. So I put a new sending unit and tank. Gauge was at E before adding fuel. I put in about 13 gallons of gas and the gauge went up to 1/4 again. What should my next plan of attack be?
Thanks
Thanks
