EL CAMINO Subwoofer is in smugglers compartment - Where to point?
HK_Camino
May 25, 2021
53
11
8
Houston
Debating whether to point the subwoofer outlet toward the seats, or towards the back of the smugglers compartment. Any one have any comments or input? Due to size limitations, these are my options.
8" sub below.
Maverick's_Monte
168
154
Rhode Island
By outlet do you mean an electrical or stereo connection or the speaker/woofer outlet? If you mean the speaker, bass is typically an omnidirectional frequency, meaning it really doesn't matter which direction the speaker fires, as long as the speaker/woofer is not mashed up against something. Highs and mid ranges will be affected by the direction the speaker is pointed, not so much with bass frequencies. As long as you have adequate clearance all the way around the unit you should be good to go.
HK_Camino
May 25, 2021
53
11
8
Houston
i meant the direction the speaker is pointed. Thanks! helpful info. I'm going to point the sub toward the seats, that way the wiring to the sub will be better hidden at the back of the storage area.
g0thiac
938
581
If it's up in the front, have it facing towards you.
And if it's in trunk, then have it facing towards the lights 😤💪💪💪
83MonteCarloSS
149
248
From my past experience you will have to try both ways. While bass is omni directional there is a point in the trunk that once you go past it with the speaker you start to lose bass big time. It might work fine either way but I would try both before permanently installing it.
